lensflare
Hi guys,
i have noticed that my 2000 BUSA (20'000 KM) have a strange idling.... i try to explain you:
when i start the engine, the idling is not perfectly
pointed, and it flows of a little 100-200 rpm more or less, but this is no real problem.
the annoying fact starts when i drive the BUSA for a while, expecially if i drive it hard, and so, when i stop it to the neutral (for example at a lightstop in the city), the idling becomes VERY instable, flowing +/- 500 RPM, so it sounds like someone is tricking with the gas...
do you think that a clogged fuel filter can cause it? or should i attempt to synch the injection bodies?
at high RPM the engine has no problems and it revs as hell
