The through the frame seat bolt is a specialized bolt , it is Metric 8mm x 1.25mm pitch , it is 55mm from head base to end tip , 27mm roughly is the thread length and the rest is a reduced shaft slightly less than 6mm . This pic is not good , but you get the idea . This one is custom titanium , easiest to order steel stocker from Suzuki . Some aluminum examples can be found on evilbay , I think Ball Z may have these .
