STROKER BUSA
busaboy
HAS ANY OF YOU HAD A STROKER 6.25 1397 HEAD WORK AND 100 SHOT OF NOS . DID YOU LIKE IT AND DID IT LAST
WOW
1535 is what it is now. 1mm over on the intake , piston speed increases when you stroke one.........make sure you got the fuel there also
kit ..............plastigauge all your crank to rod clearances............
(KYBUSA @ Jan. 28 2007,09:24) 1535 is what it is now. 1mm over on the intake , piston speed  increases when you stroke one.........make sure you got the fuel there also
Listen to the man he will save you a mint and headaches..
