The metzler's are very sticky, but they also wear out very fast. I got 2900 miles out of the rear and I'm seeing steel chords, and I got 4300 out of the stock BT56J's. Most of my riding is on the flatlands although I get to the mountains about one day a month, almost 100 miles away. If you can't get to the curvy roads quickly, you might want to consider something that doesn't wear so fast, unless you got plenty of money to burn. High speed runs absolutely square off these tires right down the middle. Great track tire, but if you ride a lot of straight roads, well you get the idea.
