Let's say for some reason (I'm an idiot) you leave your bottle heater on way too long and reach an indicated pressure of 1800 psi
Then ... you realize the problem and bleed the pressure down to 950 or so before spraying. Then, next time you spray it doesn't work. I assume the pressure overload stuck the solenoid? If it did stick is it now junk? Assuming I'm now in the market for a new solenoid, what kind should I get?
Lastly - at what pressure should the bottle safety valve have blown off?
