Jersey, I just recently changed my Coolant, I'm using Coolanol From maxima,& water wetter. Coolanol is a 50/50 mix that you don't have to ad Water to. The way I did it was Flush the whole system,Empty the radiator,then then begin to flush/pull the hose from the water pump on the Left side,stick a hose in the radiator,,start the bike,and let it run while flushing the whole system till it comes out clear plain water. Flush the recovery Tank also,and re-fill with coolant till the level line. Put the whole bottle of water wetter,and then the Maxima pre-mix,you'll see a diff in your Temp. My nedle hardly gets into the red where the fan kicks on, except in Bullshitt Bergen County traffic.
I just Came off of Amsoil 2000, 20-50 Race Oil. it was ok,,but not as good as the Golden Spectro 20-50 "Motorcycle Oil" I'm using now,smoothest shifting I've had yet on my Busa. Amsoil is great oil for cars,just ok for bikes when it comes to shifting.
161 ®
[This message has been edited by FalconCOP161 (edited 06 June 2000).]
