It's a Gen2...different system than YOUR Gen1
lease: check what forum someone posts in before
you post, or get more info on what year and what
mods have been to THEIR bike
Gen2 has no fast idle lever and the ECU has more control
over the idle circuit vs. the Gen1. Plus they have primary
and secondary injectors...he probably does not have the
02 sensor hooked up...did he use the 'required' 02 bypass?
Maybe he is using the wrong map? Might have a vacuum leak?
Lots of possibilities...need more info first :idea::idea::idea:
