My 07 Busa is lowered 1.5" front and rear the typical way. I like the ride much better this way.
The problem is that when my other half is on the back, the rear tire and the under tail meet occasionally causing a rub.
I assume by adjusting the rear spring load could avoid this most of the time, but how much??
If the stock load length is 183mm and max load is 180mm, what is the common adjustment for the 2nd rider that most people use?
I assume compression and rebaound don't need to change?
Any help is greatly appreciated as I am new to busas.
