Ononewheel
Well I started to set up the suspension on this bus. I started with the sag/preload front and rear.
I weigh about 185 lbs. 6'0"
Rear stock setting = 31.75mm static or loaded sag
front stock setting = 45mm static sag
I was looking for 25mm rear and 30mm front. Just kind of a general setting. I believe that is a little tight for street riding, but I have never had a prob.
I increased the rear a few turns, it didn't take much. It yeilded the 25mm I was looking for easily.
Now for the front, I screwed in the preload to the 2nd line just barely showing. I was not able to get the 30mm I was looking for. It wound up more around 38mm. I did not want to screw them all the way in so I left it there... for now.
Pushing down on the tank it seems to squat level ,in my opinion that is.
Took it for a ride. Seems to be better than stock, gave me a little more confidence in the curves. Now, I have not yet touched the rebound or compression. It needs it though. Seems to kinda bounce or wallow through turns with dips in them.
I will give an update to this thread when I get the damping figured out to my liking.
Oh the most important thing of all. I am not a suspension expert so take this with a grain of salt. The settings seem to work for me. I had someone who knew what they were doing guiding through the susp on my old R1 and what a difference it made. I am trying to apply the same things to the bus.
Has anyone messed with theirs?
Jeffrey
Jeffrey
