Just paid $50 to get my suspension analyzed.
The $50 includes all necessary adjustments for 1 year.
Settings are for daily aggressive rider.
250lbs (Geared)
Front Tire: Mich. 2CT
Press: 38 psi
Back Tire: Mich 2CT
Press: 38 psi
Here's the numbers:
Initial Settings:
Front
Preload: 1 Showing
Comp: 4.00
Reb: 3.00
T. Sag: 30mm
Rear
Preload: 16mm Thread/T Ring
Comp: 6.00
Reb: 10.00
T. Sag: 30mm
Final Settings:
Front
Preload: 1 Showing
Comp: 4.00
Reb: 2.00
Sag: 50mm
Stic: 11mm (No Go)
Rear
Preload: 20mm Thread/T Ring
Comp: 5.00
Reb: 4.00
Sag: 40mm
Stic: 3mm (No Go)
Recommended 1.2 kg front springs.
Said I was borderline on the rear spring and would not invest the money for my type riding (non-track days).
What you think?
Money well spent?
250lbs (Geared)
Press: 38 psi
Back Tire: Mich 2CT
Press: 38 psi
Here's the numbers:
Initial Settings:
Front
Preload: 1 Showing
Comp: 4.00
Reb: 3.00
T. Sag: 30mm
Rear
Comp: 6.00
Reb: 10.00
T. Sag: 30mm
Final Settings:
Front
Preload: 1 Showing
Comp: 4.00
Reb: 2.00
Sag: 50mm
Stic: 11mm (No Go)
Rear
Comp: 5.00
Reb: 4.00
Sag: 40mm
Stic: 3mm (No Go)
What you think?
Money well spent?
