Swapping cams...
Swapping cams... -
  • I swapped the exhaust for intake and it feels strong down low.
    Votes: 21 100.0%
  • I went with Web or other and it feels strong down low.
    Votes: 0 0.0%
  • I did a cam swap and don't feel a difference.
    Votes: 0 0.0%
  • Total voters
    21
STUNNAH
THE "STUNGUN" IS BACK!&#33
I did and intake for exhaust swap on my bike and it feels strong...I had read a bit of info that led me to believe that this would be a wasted effort...That with a turbo application and lowered compression you were destined to lag in the lower rpms...My build on the other hand feels great even in the lower rpms...
I went with Carpenter custom grind webs and a few other things. Im happy now. around 22O on motor.
BECAUSE OF A TIGHT BUDGET I HAVE TO STAY OUT OF THE MOTOR BUT IM HOPING WITH AN EXHAUST CAM ON THE INTAKE SIDE, WITH SLOTED CAM GEARS FOR DEGREEING, AIRBOX MODS AND A POWER COMMANDER MIGHT GET ME INTO THE MID 170`S LOW 180`S AT THE THE REAR WHEEL. WHATS BETTER A STOCK EXHAUST CAM OR AFTER MARKETAND CAN YA BUY THE CAMS ONE AT A TIME
You can't put an exhaust cam on the intake side - you want to put an intake cam on the exhaust side with adjustable sprockets. With a good pipe and good tuning you can get 180rwhp...
Good catch and your right on...Listen to this man...Intake on exhaust side...And yes you can buy a single cam and get the adjustable sprockets...
YES...please do not try to put 2 exhaust cams in....it will not be pretty!
I have a set of stock cams that I offered in the For Sale section........less than 2K miles on them. PM me if you are interested
If you have a TURBO, you don't want to do that. I would talk to Dennis about a TURBO cam application but pretty much what I have read is the stockers are the best bet for a basic 300HP or less TURBO bike....
That's true if your not lowering the compression...In most applications if you lower the compression you low power down low...I took a change on the cams and it worked no power loss at all...
