plan to install 6 inch extensions. i have lowered the back 2 3/4 inches and 1 inch in the front+strapped. ?? when i add the leverage to the swingarm what will i need to do to the rear shock/spring??
I installed an Gen 2 rear shock, the spring rate is higher than the Gen 1. I also played with the compression setting on the shock after I installed it. You will have to adjust for the track if you plan on running it there.
When u put the extensions on it will raise the tail a bit...... a stiffer spring wouldnt hurt either... i weigh about 250 didnt need one but to each its own!!!
