Swingarm Nitrous Bracket
McyMike
Where can I get a bracket (or what can I use to make one) to mount a 1lb bottle just in front of the tire on the flat part of the swing arm? Want to get the bottle out from under the hump.
OK Daniel - question of the day. Looks like that Schnitz bracket has the bolts coming in from the end. How do I bolt that to the center of the inner swingarm? I'm not taking the arm off to do this. If the bolts can be screwed in from the "inside" of the bracket back toward the swingarm..that should work.
Keep on posting, I love your avatar!!
(McyMike @ Jan. 12 2007,11:18) OK Daniel - question of the day.  Looks like that Schnitz bracket has the bolts coming in from the end.  How do I bolt that to the center of the inner swingarm?  I'm not taking the arm off to do this.  If the bolts can be screwed in from the "inside" of the bracket back toward the swingarm..that should work.
Bolts come from the back...Is your arm Black or silver?If silver,find a welder,take it to his shop with a rear stand,remove rear wheel,disconnect battery,mark where you want it at,let him weld it then or leave it and come back the next day after he mounts it,mount wheel and your off..
