can any one tell me what i need to remove the bolt holding the swingarm in i took both nuts off on both sides and it will not come out can any one help
can any one tell me what i need to remove the bolt holding the swingarm in i took both nuts off on both sides and it will not come out can any one help me out
The swing arm has a nut on the one end that takes a special tool.
You can make one by grinding down a socket to have the 4 pins left to fit that nut. (look at the pic and see what size is for the swing arm by matching one of them to the nut. I forget which one it is)
Then the swing arm shaft has to be unscrewed using a 6 sided tool.
(A 5/8 redi rod coupler will work if you don't want to buy the real tool)
