Switchback sockets!
GIXERHP
Well since everyone was having a hard time finding sockets the fit correctly, i have come up with a solution.
They can be purchased along with your bulbs from Autolumination!
The part number is 62-30 and can be found at the bottom of this page,
Under this listing Bayonet Pigtail Pigtail Socket Receptacles,
Here is the link to the page,
http://autolumination.com/1156_1157.htm
Now the first thing is to remove the front turnsignal socket from the bike.
Next find a socket that the housing fits into, see pic,
Next you need to push out the original socket, see pic
Then remove the ground wire and turn signal plug from the housing,
Next you need to get a slightly larger piece of wire, due to that the replacement sockets are a little smaller!
18ga, will do, then strip the wire about 3/4 of an inch and tin with a soldering iron about 5/8 of an inch
Next fold over the soldered end, and slide into the socket
Next install the new socket
Then press into place!
The wiring, now is simple, the green wire is your turn signal, and the red will be your running light!
youre a Baaad dude! good help. now, what if i just want running lights?which wire on the bike should i use to make them on all the time? i mean when i turn the ignition on
The red
hmm if it takes more than a chainsaw and a fireaxe... I will let you do them for me..
Just a quick update, been searching all morning for 1157 sockets ( advance, auto zone, oriellys.. ) and finally found what I needed at napa. PN - LS6253. It only requires that one of the twist locks be cut off flush and one sliced in half. I should have took pics but I was so excited to get them in.. lol. Hope this can help you guys out!
man this is wonderfull. 6 years later to see my posts redone over again. Funny how these thinks keep coming back round.
Tower LED's still havent changed either.
jd
