OneTrueRider
How is everyone powering the Synergy jackets. The supplied lead isn't long enough go from the Battery, out under the notch in the hump and reach the rider. If you're using the supplied lead, where do you run it and how/where do you store it when not in use?
I have a powerlet by the gauges but would like to avoid buying the adapters required to use that connection if possible. Although that would be the best/cleanest option.
I was leaning towards an SAE extension off the battery tender lead with a coax adapter, but am open to suggestions. lease :
