Hey maybe I can help out.
The atre is a fully programable Active Timing retard eliminator. It works similar to all the others.
The basic "TRE" is basically a reisister that tricks the ECU into thinking it's in a certain gear all the time thus ignoring the restriction red flag points. So 1st thinks it's in 5th etc. 1,2, & 3rd gears get their restristed power back so at about 4500 rpm it should be smoother. 6th never gets limited because it thinks it's in 5th. The only problem is that neutral thinks it's in 5th too.
The "ATRE" has little dip switches.
Programmable - user selectable option of which gears to re-map (Re-Map 1st & 2nd / 1st, 2nd & 3rd / 1st, 2nd, 3rd & 4th / All Gears)
Programmable - user selectable option of which map to use (choose between 4th gear, 5th gear and 6th gear map)
Overcomes the OEM speed limiter on 2001 Hayabusa's when set to 5th gear map
Untouched neutral map results in a smooth idle and cooler motor temps than simple TRE's
Visual Indicators - Power and Status
Fail-Safe Mode - reverts to OEM settings
Suzuki OEM connectors - no cutting of harness required
Low current consumption - max. 60mA
Over-Voltage and current protection
Epoxy protection - humidity and vibration resistant
Surface Mount Electronics used
Small size, fits easily under body work - Dimensions: 74mm x 49.5mm x 25.4mm
Only a few minutes required for changing of settings - ideal for drag-strip
Installation time 20 minutes to 1 hour
It can be set to affect each gear as you choose. SO: 1st, 2nd & 3rd can be set to 4th gear, 4th,5th & neutral will be left alone, and you can set 6th to 5th, 4th, or what ever you want. You can change it at the drop of a switch.
The ATRE is made by a board member here. They are imported from S. Africa. I have one and love it much more that the TRE I had before.
I had Ivans Tre before. It's a resister with a nicer case and stock OEM plugs on it to just plug n play. The ATRE is sorta plug n play but needs 12V power as well. Comes with everything needed.
You can find the ATRE below. I might have an extra one at the house thats unopened if I remember right. If not. I can put in a request to the MAN. Price wont be any different though.
ATRE Link
You can do a search on homeade "TRE" and probably make a basic one for $1.25. You can find posts where someone made their own with a switch to flip it on/off. All are about the same except the ATRE has much more options and does not affect neutral. Pic below.
Hope it helps.
<!--EDIT|ICEMANN
Reason for Edit: None given...|1073708789 -->
