Mythos
I recently forgot to hook up my hump lock cable and had to reach in from behind the seat and flip the latch with my finger. OMG do I ever NOT want to go through that again! Also, Always looking for ways to shed a few ounces from the bikes. So I'm thinking if I take off all the bolts under the hump and just go with the Frankenstien bolts and the bolts near the front points of the tail + the pushpins under the the tail that should be fine? You need to have the rubber cushions in place at the front or the hump will not fit tight. I've test ridden a few miles and the tail seems to run just as good without the extra fasteners.
With a little effort, I might be able to slide the tail back without unlocking the hump if I ever forget to hook up the lock cable again. Also, shead 5 ounces.
Safe enough mod?
Safe enough mod?
