Tail Swap Parts
Jbaby1969
So I’ve got more parts to do the tail swap. The subframe just showed up.
You will only use the back half of the subframe. The black pieces won’t get used
I’ve seen it done using the whole thing, but giant sleeves and spacer have to be welded on to widened the front mounting point to fill the gap, since the busa frame mounting points are really wide/far apart Compared to the gsxr subframe
Yeah just bought the entire subframe since the rear seat section was $100 by itself and the entire subframe was only a few dollars more.
