I'm considering buying a wrecked 2000 Busa and have a few questions I was hoping someone here could answer.Which year fuel tank /fuel pump will work on a 2000 model.Someone mentioned something about the mounting hole for the fuel pump is a different size on later models.Has the wiring for the fuel pump changed at all or is it the same on all models and just that 1 plug in connection.Is the bodywork pretty much interchangable from 99-05 without any mods to the plastic? Help me out guys.....
<!--EDIT|Gerald
Reason for Edit: None given...|1111076642 -->
<!--EDIT|Gerald
