for the record I have only used a wet kit
If I was to go back to a motor/spray bike.
It would be a 1441 with .385/.385 cams with a stetson head I have sitting around
the head is tapped for the foggers,
a holley fuel pump(much more reliable),nitrous pressure regulator, and the Edelbrock progressive controller(same one schnitz used to sell)
use the Map switching to control the timing
Tune the fuel pressure and jet size to whatever is needed to give correct A/F with 24 nitrous jets with 650LBS nitrous pressure
Activate in second at dragstrip and prolly fourth in LSR
And smile and go WEEEEEEEEEEEEEEEEEE
