busa_boy_69
I was hoping some gear heads here can offer me some help. I got my Busa out the past couple days and rode her. She is running strong just like normal. My problem is that this morning when i went to push her out of the garage before I had even started it when it was still in nuetral and rolling backwards I keep hearing a popping type noise that sounds as though it's coming from the chain. Now It has only had about 800 miles put on it since the last chain cleaning, however due to it being winter and it has sat a while I am wondering if the lube has kinda gotten old. I looked at the chain and it does appear a little dry. My question is could a chain that needs a good cleaning and lubing cause a popping sound every so many turns on the sprocket? I am working a ton of hours this week so I won't have a chance to clean it till Tuesday but I am hoping the problem is that it just needs cleaned. If not there may be a serious problem here and THAT is worrying me. I guess if you guys can just verify that a dry chain can cause that I can rest easier till tuesday. Appreciate the help fellas.
