Got this from the other forum
These are the best mods you can do to your bike to help it run cooler. I’m sure the 2 fans work very well, but with a turbo installed, I can only run 1 fan. Not enough room for 2.
I did this mod & even with a turbo, in stop & go traffic, in the S.C heat…..my needle never goes above the halfway line. It’s no secret that the stock cooling system is taxed. You’re sitting on 1.3 liters. That’s a big engine. The biggest problem I see with the stock cooling system is, when the fan kicks on, the bike is already running hot. Here’s what you do.
1. Install a Muzzy’s aluminum fan, make sure you bend all the blades evenly. Bend them so you will get maximum air pull when the fan is turning.
2. Install the Honda hp 50/50 premix coolant. It comes in little blue bottles. You will need about 3 or 4. In case you didn’t know water is the best coolant for your bike. It’s just not feasible to run straight water. But the higher water to coolant ratio you have, the easier it is for the cooling system to keep your bike cool. (DON’T RUN STRAIGHT WATER!!)
3. The most important step install a thermo switch from a Honda accord/civic. I went to a junkyard & got mine for free. You have to know what you are looking for & where to look depending on which car it is and what year it is. You have to remove the thermo switch from the pipe/radiator, when you cut the wires, make sure you leave enough room to wire it back to your bike. If you want to purchase a new one, the part # will be 37760-P00-003 or 37760-P00-004 depending on the car. This switch allows the fan to kick on before the bike starts to run hot.
