Tether mount on a Gen 1
White05
I bought a Boost By Smith tether, but between the choke lever and the clutch master cylinder, I don’t see how to mount it where it says in the left bar. Anybody have pictures? Do I need to remove the lever to make room?
Yes, you may need to move things to make room on the bar.
You can remove the switch housing, and then drill a small hole in the bar for the switch's plastic location pin to fit into, which will allow you to move the switch housing, if that works better for you personally.
Otherwise, just slide the clutch lever perch and fast-idel lever.
