this will be my first time,be gentile.how do i bleed the clutch fluid?i saw the other post.i'm a fair car mech.and on the older bikes,had a 1100ED zuki.but this is new,any help will be appreciated.thanks
Remove the left fairing, unbolt the coolant reservoir, loosen the clutch reservoir above, attach hose and/or vacuum pump to bleed valve on slave cylinder. Bleed normally (either vacuum assisted or pumped the old way).
