IG.
Ever since I went down in '05, my front end would vibrate slightly at high speeds depending on how bumpy the road is. Also, would move if I hit a bump. If I pull on the nose up, there is a little bit of play there (about 1-2 mm). I traced it to the upper bolt which holds the fairing stay bracket - that's the one the front cowling is attached to and it's the one the gauges are attached to. So, I looked with a flashlight thinking I just need to tighten that sucker, but it seems there is a rubber bushing in there, and also the nut is one of those which is closed on one end. So, do I just try to tighten it, replace the nut and tighten?
I know, at the time I replaced the whole bracket with a new one. Maybe I tightened OK at the time, but the rubber bushing weakened. Maybe I didn't tighten it enough.
The manual says 16.5 lbxft. Pain in the neck to reach, too.
Any suggestions?
Any suggestions?
