After the Christmas festivities died down today, I came home to button up the busa for it's appointment at the dealer (click in case you didn't read my earlier post). In the process, I decided to check the Fuel fuse. It tested fine, so I plugged it back in and just for the hell of it, I turned the ignition on and viola! That beautiful fuel pump noise and a working starter! As I fiddled with the wires going into the fuse block, the fuel pump noise would come and go, and I felt a loose wire snap back into the fuse block. So, I buttoned everything up (except the fairing cover over the fuse block) and took it for a little spin. No problems at all. So tomorrow after work I plan on taking the fuse block off and checking for any weirdness. And if all goes well, taking a "spirited" ride
