FlatlandBusa
As some of you know I pull a third wheel trailer instead of carrying luggage on the bike for the wife and I. It has been a great addition to the Busa for trips but the damping of the suspension has always been lacking. After 2 years and 5000+ miles I finally decided to do something about it. The stock shock is just a twin tube oil filled affair which doesn't perform at it's best when in the horizontal position on the trailer, particularly on very rough (Nebraska) roads when heavily loaded.
After spending some time researching options, I settled on this one. It's a gas charged mono-tube.
http://www.scooter-speed.com/products.php?2443&cPath=56_69_608
Installation was a simple bolt and go, however I had to remove a couple washer shims as the mounting points were very slightly wider.
I just returned from a 50 mile test ride on the roughest roads I could find, with approximately 70 pounds in the trailer and damping is far better. Stability through very rough corners is very good. Even when going over rail road tracks and the ramps to bridges which are rough enough to require standing on the pegs, the trailer remains settled without any of the bouncing it had previously exhibited.
Most importantly the severe high speed vibration the trailer suspension experienced at 70mph+ is gone. This vibration couldn't be felt in the bike but is very visible and both my trailer and my brothers exibited it. This vibration was approximately 1 inch of movement at the tire and was eratic in frequency and checking and rebalancing the tire did nothing for it. Now everything is smooth and settled to 90+.
