So I've had the typical idle problems, where it drops after a month or two and needs to be adjusted. Did it myself this time, dialed it in just right, idles at 1100 when warmed up fully.
Only problem is now, when starting cold, it idles around 800 and the choke (fast idle) lever, it does nothing!
I thought I saw an adjustment screw for that too, hard to reach but will that make any difference? I had to crank up the idle screw quite a bit, so is it normal to have to increase this too?
