when I am cruising along at a slow pace and whack the throttle, I get a half second or so lag...it almost bogs like throttle closed for a mili to a half second and then wham...full power.
The bike runs really well other than that (and it's driving me crazy).
I've got an HMF dual high rise with a power commander running the map off the PC website.
I noticed this a little while back, at the time I was running a map a buddy sent me, so I took it off
and put the webmap on and balanced the throttle bodies and took off my tre. Didn't help...(this was about a month ago)
I did a search of the board and and reset the throttle position (high and low) on the power commander and retweeked/rebalanced the throttle bodies (last week)...lag is still there.
I also tightened the throttle cables, I like em tight. I actually got em to tight and had cruise control...whoops, backed 'em off a bit...didn't help.
I was cruising yesterday and the light hit yellow on me, so I whached it...there was the lag/closed throttle again.
Everything else is good, plugs changed every 7000, oil changed every 3000, bmc air filter...I'm out of ideas short of letting the local idiot stealership rob me for it.
Any ideas, do you think a custom PC map would eliminate it?
