I'll be riding Medusa over, regardless of how cold it will be next week .(thebbbusa @ Feb. 08 2007,17:39) I don't remember what ours was, but it was in the 20s when Rhythm and I tackled Medusa. We'll do Agent Orange next week, if you're still wondering then, I'll note what we get.
+1!(MC MUSTANG @ Feb. 08 2007,21:05) Most people will tell you that it doesn't matter what the reading is, as long as they are all matched up.
I was going nuts because I wasn't able to get all four the same level. and I notice the the jump from time to time when doing the adsjustment is that normal?(omslaw @ Feb. 09 2007,06:18)+1!(MC MUSTANG @ Feb. 08 2007,21:05) Most people will tell you that it doesn't matter what the reading is, as long as they are all matched up.
Don't worry so much about the numbers. Just get all 4 as close to the same as possible.
Just get them as close as you can. It's a little hard to get them much closer than 1cm since the engine is running and all 4 are bobbing up and down at different times. The point is really to just get them as close as you can relative to each other.(elmostro @ Feb. 14 2007,14:53)I was going nuts because I wasn't able to get all four the same level. and I notice the the jump from time to time when doing the adsjustment is that normal?(omslaw @ Feb. 09 2007,06:18)+1!(MC MUSTANG @ Feb. 08 2007,21:05) Most people will tell you that it doesn't matter what the reading is, as long as they are all matched up.
When you started, were they close? Then you adjusted them to match. I suppose if you cranked them all up a lot higher or all down a lot lower than where they were it could make a difference.(elmostro @ Feb. 16 2007,13:01) I just did the TBsync and notice gas mileage drop from 30 to 22mpg. help please. also notice little white smoke when I hit the gas hard and let go the gas at the end some white come out. when idle everything is fine no white smoke. when riding no smoke visible niether.
I don't know what to tell you. I have a feeling you've gone out of spec because of your method. But that is pure speculation. I am speculating that your decrease in mileage is from a vacuum that is either way too low or way to high after your syncing. We really need to know now what right setting should be so you can get back close to it.(elmostro @ Feb. 16 2007,20:30) I have no idea. but I think that if i close them all the way and open them little by little I might be able to get them right. now in which direction is closing, left turning towards the #1 TB or right, toward the #4 ? what you guys think?
