I noticed in addition to an internal spring, the Tial BOV's also have an air fitting on top with a 10mm hose barb for "quick actuator response". One of the posts I read in the past mentioned how some BOV's also incorporate a Pop-Off Valve. Is that what the purpose of the air fitting on the Tial is for?
I've seen references to Blow-Off Valves (BOV), Pop-Off Valves (POV), Hobbs Switches and Bypass Valves.
I completely understand the BOV and Hobbs Switch but I'm not quite sure how a POV operates, nor have I ever (knowingly) seen one. I'm also in the dark about a Bypass Valve, or is that just a different name for a BOV.
