The Fletch
just a quick question what do you run your tire psi at for street/highway for average riding?
Same here 40 to 41 both ends on battleaxes. I found out a couple bikes ago that 40 gave a little softer ride than 42 but still (hopefully) gives me maximum tire life. Although the Busa's suspensions so plush I doubt it really makes any diff. I've never had any traction probs either.....knock on woodrun 41 fr and rr in stock battlaxes.
maybe Im doing things backwards.Tire pressure is all about creating heat in the tire. More pressure, less heat. Since your bike weighs the same on both ends, what's the reasoning for running less air in the front and more air in the rear (Unless you have a fat chick on the back of course)? I've never really understood that since the rear is larger than the front in order to give you more traction for throttle and/or hauling heavy loads?
All the hard core guys I know run two or three pounds less in the rear. All the articles you read in magizines on tire tests, they never run more air in the front, why?
I'd be interested in your answers as to why you want more air up front?
