I run a Shinko on the rear, and a Diablo on the front and I ride aggressively.......but only in a straight line!Not really, but if you ride aggressively............
Guys/Gals, will it cause any problems running a BT015 on the front, and a BT016 on the rear? I usually run the same tire on both wheels, but don't want to replace the front this time. Thanks for your response in advance.
Thanks guys. I am not a super aggressive twisty rider. Do any of my aggressive riding in a straight line, and mostly commute anyway. Any opinion on whether it would be best to stay with the BT015 as opposed to the BT016? Whichever will give the most mileage?
Any comments if I used a BT021 in the rear with the stock BT015 front as my rears are toasted? Don't really want to let go the front as it still has lots of thread.
only partially true.. the 021 will wear faster on the front than the 016... already proved that through 2 of them.. The 016 will outlast the 021 on the front and I think it is due a lousy compounding of the tire.. it slips around too much and wears itself out.. well at least on the Gen 1 bike (plus it handles awful IMO, never ever got comfortable on the 021 front)15 is the stock tire and works well for all around riding. The 16 is better in the twisties and will last as long as a 15, because of the triple compound rear and the dual compound front.
BT021 is a harder compound tire and will last longer than either the 15 or the 16...sticks ok in the corners...just not as well as the other two.
only partially true.. the 021 will wear faster on the front than the 016... already proved that through 2 of them.. The 016 will outlast the 021 on the front and I think it is due a lousy compounding of the tire.. it slips around too much and wears itself out.. (plus it handles awful IMO, never ever got comfortable on the 021 front)
I went with a Dunlop Qualifier on the front and had a blast... removed it and put the 016 and it was nearly as good, the Qualifiers are a better tire for me.. (but they are also a bit more $$)
they "said" the fixed it.... no such luck... I got their new "fixed" tire... sucked as bad as the others...
They had a batch of defective 021 fronts...they fixed that
How a company can make such good tires and then put out that 021 front? beats me but it is not a tire for the Busa...
I was one of the guys in touch with BS America over this tire problem.. They sent me the "new and improved" compound tire and this "dood" was last season... I ran them at Eureka springs brand new and they sucked..How many YEARS ago was that dood
Got them home and the first one was toast in around 3000 miles while the rear was still doing fine..
When did you run the 021's?
