c10
Even if your never in the market just enjoy the read
Zeta Z-Titanium Front Axle - 2008-17 Suzuki GSX1300R Hayabusa
Copy/paste if you dont like links
Please Note: this is for the front axle ONLY.
LIGHT WEIGHT
The specific gravity of Ti-6AL-4V is about 4.4. This is about 56 % with respect to the specific gravity of 7.8 of stock axle shaft using iron( SS400 ) and carbon steel ( S45C ), or chromium molybdenum steel shaft ( SCM440 ). This means that if you manufacture the axle shaft in the same mass, 64 titanium will be able to produce about 44 % reduction. The reduced weight of the axle shaft also reduces the unsprung weight and corner approaches will improve the handling and stability. In addition, the reduction of unsprung weight will not only improve the movement of the suspension, but also improve brake performance.
ULTRA STRENGTH
Strength of Ti - 6A L- 4V is comparable to chromium molybdenum steel ( SCM435 ) 900 - 930 Mpa. With the higher strength axle shaft, you will be able to feel more road surface information more directly. You will be able to sense the differences in road surface that could not be felt until now.
BENDING
The Young’s modulus of Ti-6AL-4V is about half of iron and chromium molybdenum steel at 106 Gpa. The Young's modulus represents the rigidity and elasticity, the higher the number, the higher the high rigidity. Generally, one thinks "high-strength = high rigidity,” also 64 titanium has been taken for granted as high rigidity, but actually it is only half the rigidity of iron. Therefore it easily deformed, but there is elastic deformation where a material tries to return to it’s original state and plastic deformation where deformation is permanent. 64 titanium has a wide range of elastic deformation. In other words this is "BENDING". It is this bending that produces the suspension effect, and high strength that softly transmits road surface information.
Not only Light. Not only strong. Not only flexible. If it is made of aluminum or magnesium it will be lighter than 64 titanium but it will lack strength. If it is made of chromium-molybdenum steel and nickel-chromium steel it will be stronger than 64 titanium, but it will be heavy. There is also materials having Young's modulus lower than 64 titanium, but it will not mean that there is "BENDING.” 64 titanium is superior to a balance of these materials. Therefore it may be said that it is the best material for the axle shaft.
Also we must not forget the appearance of titanium. It more difficult to rust than stock shaft and chromium-molybdenum steel shaft that has a protective surface treatment. However, it does not escape corrosion where the surface is compromised for some reason. Ti-6AL-4V forms a passive film surface to prevent semipermanent rust to form.MaterualMaterial symbol and heat treatmentTensile strength
(T/Mpa)Young's modulus
(E/Gpa)Specific gravityRolled steel for general structureSS400(Annealing)4502067.87Carbon steel for mechanicalstructureS45C(Normalizing)570 or more2057.83Chromium-molybdenum steelSCM440
(Tempering quenching)980 or more2067.86Austenitic stainless steelSUS304(Solution treatment)520 or more1977.93Pure aluminumA1085 P(Annealing)55692.7Duralumin
(aluminum alloy)A2017 P(Natural aging)355692.79Ultra duralumin
(aluminum alloy)A2024 P(Natural aging)430742.78Extra Ultra duralumin(aluminum alloy)A7075 P
(quench-and-temper)573722.81Pure titanium (JIS grade1)TF270275-4121064.51Pure titanium (JIS grade 2)TF340343-5101064.51Pure titanium (JIS grade 3)TF480481-6181064.51Titanium (αalloy)Ti-5AL-2.5Sn8501184.48Titanium (α-βalloy)Ti-6Al-4V900-9301064.43Titanium (βalloy)Ti-15Mo-5Zr-3AL147075-954.8
Top Rated
1Liked a while ago
Contact Us
Quick Links
Join Our Newsletter
Get all the latest information on Events, Sales and Offers.
Sign up for newsletter today.
LIGHT WEIGHT
ULTRA STRENGTH
BENDING
Top Rated
2015-17 Yamaha YZF-R1 / YZF-R1M / R1S Race ECU Flash
5.00
$215.00
09-14 Yamaha YZF-R1 Race ECU Flash
5.00
$110.00
Superbike Unlimited Rear Brake Rotor - Yamaha, Suzuki, Honda, Kawasaki, BMW
5.00
$105.00
1Liked a while ago
Contact Us
- 170 Bradley Branch Rd
Suites 2-4
Arden, NC 28704 - Phone 828-676-2222
Quick Links
Join Our Newsletter
