Took off my front sprocket to replace it
MC MUSTANG
Hokay -
So, my stock sprocket has rubber bushing like material on both sides, the new JT sprocket has none... Dumb question, I know, but is this an issue? Do I need to do anything other than just put it on and torque it down?
Thanks...
The rubber is for noise, vibration and harshness, good idea too because the jt is going to sing like a jail bird. I got use to mine, nothing else needed except some red locktite and torque it down. Make sure you use the locktite on the speed sensor, they have a history of coming loose, will tear up your case. Best mod I have done to date!
Thanks for the reply --- will do!
I will be putting it on tonight! Thanks again for the gouge!
