Fyi
Bent shift forks are not uncommon to find in most sportbike engines.
The main causes being abuse, and more so, the front sprocket nut being broken loose with the transmission in gear, especially using a breaker bar, as the torque is applied much slower than with an impact.
And, it's not just the forks themselves that can get bent, but also the pins on the opposite ends of the forks, that slide through the grooves in the shift drum.
The drum grooves can even get a lip or sharp edge along the sides of the groove/track, and they may need filed smooth.
The original problem with the gears themselves, specifically 2nd, and sometimes 5th, has no exact cause.
Some bikes have a slipping 2nd, some don't, with mileage, maintenance, or abuse not really seeming to be a factor one way or another.
What the probelm really seems to be is, is that some gears seem to be on the high end of tolerance, and other gears on the lower end.
Now, randomly assemble these parts, and with a little bad luck, you get 2 or more parts that eventually don't work as well together.
A new angle can be cut on the gears to help them mesh better, but as said, if that doesn't correct the slipping, then there is likely not enough material left on the gear(s) for them to be cut again.
Buying a new 2nd gear, or even all of the gears, forks, and transmission components garauntees you nothing, those too can slip.
This is almost completely a Gen1 problem as well, and it is rarely a Gen2 issue.
The Gen2's have a slipping 2nd about as much as any other sportbike, which in those cases, almost always comes from abuse.
