171.12 MPH corrected by the 8% average adjustment that is required as standard for most Busa speedos. 186 if you run the standard (non-export) Japanese gearing. 193 MPH unrestricted with perfect conditions, but you'll need abot 213HP to overcome the drag at this speed.
Disclaimer: All calculations are based on my speed/gearing spreadsheet, and do NOT account for rider posture, weight or skill level.
171.12 MPH?
So the zx11 went faster than the current busa because of the busa limiter?
So indicated, will my speedometer stop at 186? And if it did, then the bike itself is only going 8% less which means it is not actually even going 186.
I would think that the restriction was supposed to be for true speed at 186. Thus the speedo would read 200 or more as the 8% loss brings the real speed down to 185-ish.
Im still confused, sorry.
