Just fitted up this top triple clamp set up with offset clipons . Had a short test on it and it feels quite good , the bars are lower but the bar angle is the same as stock 7 degrees , and the bar is back towards the rider . Now , I took a gamble on this setup to cure my RCS Brembo brake master cylinder from activating on my dash on extreme turn . Usaually only affects when pushing the beast around , but did actually get me when I pulled up to park the other week on a ride ! Now , no worries , just clears nicely .
Now the top clamp is from Agras (owned by Mikuni ) , and does come with clipons but they weren't going to help so did not use them . The clipons are Renthal gen 3 .
Now the weight of top triple with ti bolts is just under 650 grams , and the clipons weight 207 grams each with ti fasteners . I will give it a longer test soon , but just not reaching forward as much felt good , and combined with lower rearsets , well I looking forward to testing .
