Torque thread prep for Titanium / Aluminum
Flows
Has anyone installed these before? If so what thread lube/lock compounds did you use and what torque settings?
For example the factory setting for the front mount A,B,C,D 10mm bolts is (C) 55NM (see page 4 attached) while Probolt recommends a max torque of 38NM lubed for the tapered socket heads. Then what do we do with the Alloy frame inserts? Lubed we are usually dialing back 30 - 50% on torque settings and Ti has a different friction coefficient from steel but Probolt also recommends using factory settings where able. What is best practice here?
  • Engine installation.pdf
