Front brake caliper mounting bolt - 28 lb-ft
Front brake caliper housing bolt - 15 lb-ft
Rear brake caliper mounting bolt - 19 lb-ft
Rear brake caliper housing bolt - 21.5 lb-ft
Engine case cover bolts? Not sure which bolts you are talking about. The clutch, starter clutch, generator and gearshift cover bolts are all (7 lb-ft). The crankcase bolts are based on the size of the bolt.
