OB_Tweaked
*** Cross posted to modifications section too ***
So, I just had a Yosh duplex RS3 installed (race baffle). I would normally do all this myself, but with FI, I just took a seat. They adjusted the TPS and set the remapped the stock box at +5,+10,+5 with a Yosh box. I now have the following problems:
1) It doesn't like small throttle openings either taking off in 1st or transitioning throttle on/off in any gear. It has a pronounced hesitation or studder. Seems worse as the bike warms up.
2) It seems fat at idle. Its not crisp and blipping the throttle a couple of times will send the RPMs below 1k, then it will recover (rich on carbed bikes).
The tuner doesn't notice the problem, but I have a finely calibrated seat in my pants;-) They had said they set the TPS at 11 o'clock whatever that means? So, I checked the TPS as outlined here and it looks right (-C00). Can it be slightly off and the indicator still be right? The indicator doesn't move up until somewhere around 1750rpm. Anyhow, doing this I stumbled onto something. With the connector jumpered to check the TPS the idle problem (#2) goes away! As soon as I apply the jumper, the bike idles up a bit. I did all this with the bike at temp, on a stand, in neutral (of course). The throttle response is crisper and it never goes below idle speed (1100) when blipping. Now, what exactly does this jumpering do? Maybe a mapping default? Can I ride it like this (I'd like to see if problem #1 goes away)? HELP!
