Quiksilver
2002 gen 1 turbo pc3 is. So I'm having this peculiar problem I haven't came across before, my to wont stay put. I have set multiple time before with no issues now I'm having issues. I have two used tps sensors that ohm out good. In dealer mode the tps bar is at bottom, I crank up for a to middle and rpa are around 1200 then I accelerate it goes to top. I notice at lights it can be on the bottom bar or top and when rolling off the throttle the tps position will be at the top. Pc3 unplugged and I can tell no difference. Could the pc alter the signal sent to the dash? I've seen like 5% at idle on pc3 and the bar on dash is at the bottom. Could throttle linkage or the throttle bodies be out of wack? Ecu possibly
