I am in the process of doing the transmission on a fellow busa riders bike however I have found a crack in his lower engine case around the bearing for the shifter rod. I know that it can be welded but in the event that it cannot, do any of you have a set of cases available and if so what price? Also will need the following parts:
water pump and bolts
countershaft sprocket cover and bolts
tranny-complete with shifter cover and all internals
including bolts
clutch pushrod
gasket kit
If anyone here has these parts I would love to get some contact info?
I appreciate your help and advice.
Thanks
including bolts
clutch pushrod
gasket kit
Thanks
