Let me make this easier, WHAT is the resistance in Ivan's TRE?
No let me make this easier.
Do your own research, I have done mine. You seem to have all the answers and consequently won't believe anything you read here.
Contact Ivan ( I have, again, 5 minutes ago) and ask him the question yourself. He said he needs to update the web page.
Ivan's Rockland County Motorcycle
1630 RT. 202
Pomona, NY, 10970
845-362-1212
You may also be incorrect about how the ECU limits function.
The 99-00 ECU retarded the timing in all gears but 5th-6th. The TRE for those years makes the ECU think it is in 6th gear, hence removing the timing retard. (99-00 TRE uses a 6th gear resistor for all gears) Those years the ECU had no restriction on RPM in 6th.
The 01-02 ECU restricts the RPM in 6th gear so it consequently restricts to top speed. The TRE makes the ECU think it is in 5th gear so the RPM can go above 10,500. (00-01 TRE uses 5th gear resistor). I also believe the maps in the 02 are slightly different.
In the early Busa years (99-00) the riders in the UK discovered that better performance could be had by using the 5th gear resistor and were using that instead of the 6th gear resistor from day one. I took their word for it as I haven't tried it.
This topic has been beat to death on LaBusas and SH.org. Go to either site and do searches on "TRE 02" or better yet call Ivan. Like I said, his response (which I read) addressing this issue on sh.org was lost.
If you won't take my word for any of this, just call Ivan. That's what I do when I disagree about some issue. Just go straight to the well. In this case Ivan, the inventor.
To everyone else yes Ivan's TRE works on the 02 Busa.
