trun indacator light
1397juicedbusa
here is a good one for you guys.......my turn indacator light goes out on the dash so I go to the Suzuki shop, walk up to the parts counter and ask for a new bulb......they look and tell me there are no bulbs listed for the hayabusa, I ask how the hell does it light up and the tell me WE DONT KNOW........lmao.....anyone have a part number or anything?
I looked in my copy of the parts book and couldn't find a bulb listed. The only thing it shows is the cluster. It may be a built in led that is not user changeable.
Your external bulbs flashing? If one is out you'll have a fast flash or no flash at all. The indicator lights are LED and not easily replaceable. I believe the actual sognal bulbs are 2056 bulbs, or 2056NA, but off hand I'm not positive.
Posted via Mobile Device
its a simple l.e.d. on the dash circuit board, if u are hand with a solder gun and know how to de-solder then its a very easy fix.
I'm not sure I would call it an easy fix since it means removing all the gauges and circuitboard but is doable...
If it is a GEN I Busa, you needn't remove anything except the cover panels. When done you'll see a normal LED on the left top side of the circuit board.
BUT from my point of view check the LED's electrical signal first cos I have never seen a dash's dead LED yet...
Ciao
D1
Ciao
D1
Sorry... Was thinking of the ones you replace when you want to change the color... My bad...
+1 on the dead led. Never seen one so far.. But sometimes has to be the first.. :D
