plus ignition
btw:
did u ever summarized all amperes / volts of these parts , the running engine, need while a run over a 1/2 (or 1) mile ?
sorry, but have you ever thought about how much electricity the generator can deliver to the battery over this oh so long distance and by how much it can actually be charged,
or how much power such a generator delivers?
experience has resulted in the fact that a generator is only able to charge a battery
that is only half full over a really long distance to around 75% - and i'm talking about a distance of well over 100 miles here,
because of the generator does not have this great performance.
neither at motorcycles nor cars or trucks - nowhere & never
it's a nonsense to think that you can charge the battery on the race track.
you can never avoid having several fully charged batteries with you or somehow recharging the one that was built in after each run.
and with the turbo with the generally reduced compression, it takes a lot less power to turn/start the engine,
so that even a 6Ah lifepo (12V) is completely sufficient.
a good friend drives with a yamaha fj1200 on the circuit with a kind of plug-in system
after each training sessions and after each race he simply puts a second, recharged battery in the motorcycle and has power on board again for more than 30 minutes.
and because of the CCA - the 6Ah lifepo has around 360 CCA which is perfectly sufficient to be able to start even a small (2 liter) diesel.
ur idea of 24 volts in my view will only cause lots of issues
first - where to get the 24 V ignition coil u would need ?
and second - a 24 V starter / ecu / etc.
and what to do if one of these super special 24 V parts fail / crack at race place?
in my view ur nuts if u wanna follow that 24 v - plan further on.
