Vspec
OK last nite coming home around the M25 J10 accelerated away in 5th on low boost (10psi) at around 6000rpm it seemed to rev then backfired and will not start.
After investigation this morning, NO fluid leaks, turns over and no noises from engine on turning, compression on all 4 the same, spark on all plugs (changed 3 weeks ago) No pipes blown off.
It run on Seans Turbo Day at 18psi to 10000 with no probs.
Any ideas guys without stripping engine?
Will double check fueling map this afternoon with the laptop!
