Deez ballz
Hi Guys, got a GEN 2 2017
I need to install a external fuel pressure regulator FPR 800 turbosmart for a 1:1 ratio. Where do I put the return line. I'm confused,
pump> fuel rail > regulator ? > return to tank?
There is only one outlet from sender unit.
Iam installing a AEM 320LPH@42psi intank fuel pump. Do I remove the intank Regulator completely.
I Will be using 6an fittings for fuel lines. Is that a good idea ?
Should I need to buy a billet fuel rail with 3/8 npt
3 ports.
I have very small room under the tank for this setup. Because of ABS unit taking room. Any Photos will be helpful on routing.
Thanks guys.
3 ports.
Thanks guys.
