turbo/gix trix
OB_busa
STAGE 1,I WAS TOLD THE SAME SYSTEM WILL GO FROM 250HP TO 450HP DEPENDING ON INJECTOR SIZE AND ECM REMAPING.I HAD SPOKE WITH REX.
Adding a intercooler, pistons, and some other things of course. He meant you will use the same turbine not having to upgrade to a different one. But you will have to upgrade your ecm. You can go from 250 to 350 hp fairly easy. Add pistons or lower compression and add the intercooler. Going to the 400 + hp range is a little more complicated.
I have. I sale his turbo kits. They are on the lines of mc-xpress as far as craftmanship goes. Which system were you looking at, 200, 300, 350 or over 450 hp?
